Online Now [91]:
Visitors: 91
Today: 13145
Total: 138748506
Forums › The Car › 206 Problems › Ignition Switch Broken?
mattmanic
PostPosted: Mon Apr 20, 2015 1:32 pm Up
Hello, my key seems to be getting stuck slightly above position 2 which is occasionally causing the starter motor to stay on after starting, and meaning interior electronics are off/getting low voltage until I physical turn the key back the where it should be. Do I just need a new ignition switch or will I need a barrel too? And is there I guide for getting the switch off the barrel? I was able to work out how to hey the barrel out but I couldn't get the switch off it.
Thanks Smile
