Online Now [341]:
Visitors: 340
Today: 44023
Total: 142665398
Forums › The Car › 206 Problems › 206 GTI hydraulic tappet problems
andyleep
PostPosted: Sat Apr 25, 2015 3:26 am Up
I see these can be a common fault that causes bad idle when cold. If they are at fault, could the problem be intermittent or would it be all the time?
PostPosted: Sun Apr 26, 2015 2:42 pm Up
usually a good clean fix it,but usually its a perm. fault that need to be fixed.
andyleep
PostPosted: Mon Apr 27, 2015 10:52 am Up
So if it only runs rough from cold every now and again it probably won't be the tappets?
