Latest: airmastertapes
Overall: 17133
Online Now [525]:
Visitors: 524
Today: 27209
Total: 106560840
Forums › Tuning, Modification & Legal › Project Cars › Introducing Yev
Introducing Yev
neilneil2000
PostPosted: Sun May 03, 2015 3:31 am Up
Hello!
I have recently made a somewhat spur of the moment decision to purchase "Yev" my W reg 206GTi. Bodywork is clean but has a few issues that I need to work through.
The aim it to build a dedicated track car, essentially to be faster than my brother's 106Gti!
Purchase date: 26th April 2015
Air filter replacement (K&N panel): 30th April 2015
Spark Plug change (Bosch Super 4): 2nd May 2015
Current Issues:
Pull left under acceleration
Hunting for idle when cold
Clunking from rear suspension over bumps
ToDo:
Brake disc thickness check
Read error codes
Bleed brakes and replace with Dot 5.1
Strip out and sell interior
Replace gearbox oil
Replace engine oil
Replace fuel filter
ukskater01
PostPosted: Sun May 03, 2015 3:48 am Up
Welcome, have you checked the axle for play? Jack it up and pull on the wheel to check for play in the bearings
cainw1
PostPosted: Sun May 03, 2015 7:54 am Up
Sounds like an interesting project.
Whats your brother's 106 gti like?
neilneil2000
PostPosted: Sun May 03, 2015 12:25 pm Up
Skater: I have tried the left front but haven't got round to the others yet.
Cain: heavily modified, aftermarket ECU, cams, decat, fully stripped out. And I'm a good 3 stone heavier, so both me and Yev need a diet!
2000 (W) 206 GTi pre-plex RFR EW10J4
neilneil2000
PostPosted: Mon May 04, 2015 1:49 am Up
I'm on a tight budget, so where's the best place for me to look for secondhand aftermarket parts?
Shadowstalke
PostPosted: Tue May 05, 2015 11:15 am Up
Fleabay. 206 Owners Club UK (search on Facebook)
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
neilneil2000
PostPosted: Sun May 10, 2015 2:37 pm Up
Engine flush and oil change today - seems to have solved my hunting for idle problem, let's hope it stays that way!
I have set myself up a Patina Log of activity here:
www.getpatina.com/vehi...m8lMV0Hjlq
neilneil2000
PostPosted: Tue May 26, 2015 5:26 pm Up
A busy bank holiday weekend for me.
Most of the stripping out down
Cam belt changed
Drive belt replaced with non A/C version
Cat back exhaust installed
Pictures to follow!
neilneil2000
PostPosted: Sun Jul 19, 2015 6:11 pm Up
Much more stripping out done now. The only things left inside are:
- Front Seats
- Steering Wheel
- Front metal crossmember
- speedo/tacho cabletied to the cross member
#LightweightBaby
neilneil2000
PostPosted: Sun Jul 19, 2015 6:13 pm Up
Have now also removed all the Air-con system: condenser, compressor, evaporator, pipework etc. And the charcoal canister and piping from the fuel tank.
Gearbox Oil changed
and
Pug1off solid gear linkages and short shift kit fitted.
neilneil2000
PostPosted: Sun Aug 16, 2015 2:41 pm Up
Front fog lights removed
Gaz coilovers, new top mounts and lemforder drop links fitted
Air intake modifications started
