Online Now [338]:
Visitors: 337
Today: 98348
Total: 142366393
Forums › The Car › 206 Talk › heater matrix
heater matrix
skybluebert
PostPosted: Wed May 13, 2015 5:03 am Up
From the research i've done I believe the heater matrix is on the way out. Is this something my normal garage can deal with or is it a peugeot only job
David1156
PostPosted: Wed May 13, 2015 5:29 am Up
I believe it's a job that any decent garage should be able to handle. Contrary to popular belief, you don't need to remove the whole dashboard to get to it. It's just the glovebox assembly. If you're looking for a quick fix, you could try some radweld. That's what I used a couple of months ago and it's been fine since.
Current: Albi Blue Clio 197
skybluebert
PostPosted: Wed May 13, 2015 11:06 am Up
Cheers. I'd rather get it sorted to be honest
skybluebert
PostPosted: Wed May 13, 2015 12:42 pm Up
Am i right in thinking that it wont leak if i keep the fans turned off
PostPosted: Wed May 13, 2015 1:12 pm Up
Nope. the coolant runs through it whether the fan is on or off and the heater is set to hot or cold
skybluebert
PostPosted: Wed May 13, 2015 1:19 pm Up
cheers
