Latest: Puggingalong
Overall: 17129
Online Now [338]:
Visitors: 337
Today: 34963
Total: 101159756
Forums › The Car › 206 Talk › What's the best front splitter to put on a Peugeot 206?
Liamhalsey206
PostPosted: Wed Jun 17, 2015 12:18 pm Up
Want to find out what's the best spiltter to put on a Peugeot 206?
PostPosted: Wed Jun 17, 2015 12:39 pm Up
Whatever is cheapest down the scrapyard.
Luckily the 206 is so old now that a lot of the tacky bastardization stuff is no longer available.
Shadowstalke
PostPosted: Thu Jun 18, 2015 4:23 am Up
Laguna, Clio and Leon Cupra R splitters are popular
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
Liamhalsey206
PostPosted: Thu Jun 18, 2015 6:39 am Up
thank you i knew some other cars fitted but never knew which ones aha hopefully to find one now Smile
Shadowstalke
PostPosted: Fri Jun 19, 2015 8:12 am Up
Any splitter will "fit". None of them will go right on, you will need to cut, hack, slash, glue, screw, hammer, staple etc as required to make any splitter other than a 206 splitter fit.
No Smoke, No Poke!
PostPosted: Fri Jun 19, 2015 4:49 pm Up
And they all look s**t!
PostPosted: Sat Jun 20, 2015 3:37 am Up
www.206info.co.uk/Foru...30910.html
customized206
PostPosted: Sun Jun 28, 2015 4:33 pm Up
Laguna one on mine !
custom 206 van in the works
MrWhite
PostPosted: Mon Jun 29, 2015 11:36 am Up
£5 astra mk4 splitter from scrap yard.
My 206 Project Thread
