Latest: Beduff1977
Overall: 17134
Online Now [343]:
Visitors: 342
Today: 17427
Total: 107198356
Forums › The Car › 206 Talk › 180 brakes on my 1.4 HDI (i have no ABS)
pug_206_uk
PostPosted: Fri Jun 19, 2015 5:49 pm Up
been offered some cheap 180 callipers (only thinking of doing it as i need new discs and pads) just wondering will i need to upgrade the brake servo just i have no abs on my HDI or will they bolt up with no problems?
Peugeot 206 1.4 HDI - July 2013 - Present
PostPosted: Sat Jun 20, 2015 1:18 am Up
Servo is nothing to do with the hydraulics. You need to make sure the master cylinder is big enough.
pug_206_uk
PostPosted: Sat Jun 20, 2015 2:06 am Up
will that need to be changed in order to fit the brakes?
