Latest: Beduff1977
Overall: 17134
Online Now [149]:
Visitors: 148
Today: 58720
Total: 108581955
Forums › The Car › 206 Talk › Gti 180 coil pack
Gti 180 coil pack
mattymj
PostPosted: Fri Jun 26, 2015 3:31 am Up
Hi all
My 180 is a little rough on idle. Engine shaking but run ok once warm.
I'm suspecting the coil pack as it's the original sagem one.
What is the best coil pack to change to?
Euro car parts list 4 types. They have a good discount on at the moment.
PostPosted: Fri Jun 26, 2015 6:28 am Up
Could be hydraulic lifters if it improves when warm.
mattymj
PostPosted: Fri Jun 26, 2015 9:49 am Up
The revs also waver a little on idle!
