Online Now [62]:
Visitors: 61
Today: 20081
Total: 140013957
Forums › The Car › 206 Problems › 1.4HDI P0202 Code
1.4HDI P0202 Code
A10PSW
PostPosted: Wed Jul 01, 2015 1:56 am Up
Hi My 2005 1.4 HDI is running a bit rough every now and then and has thrown up a P202 code which is - Cylinder 2 Injector Circuit Malfunction.
Which is the No2 Injector? is it from left to right as you stand in front of the engine?
It says on google that it could be a bad injector or wiring to the injector.
Shall I swap the injector with No3 Injector to see if the proplem code changes to P0203 which will rule out a wiring problem and confirm its the Injector?
Is it quite easy to get out the injectors?
Do I need new seals if removing injectors?
Sorry for all the question!
