Online Now [75]:
Visitors: 74
Today: 36695
Total: 140143432
Forums › The Car › 206 Problems › GOING MAD!! P0110, P0300, P0170
dmsempire
PostPosted: Wed Jul 01, 2015 1:30 pm Up
Okay, so it has a new MAP sensor, cleaned throttle body, including new gaskets and cleaned intake manifold, cleaned idle sensor, replaced post cat O2 sensor, spark plugs, oil and oil filter, air filter, cleaned all injectors, had new crankshaft sensor and knock sensor, the EML went away for a few days and now it's back on with the following errors: P0110 P0300 P0170. I had a look at the exhaust manifold gaskets, they seem to be good, not broken or anything. WHAT IS GOING ON WITH THIS CAR?!?!?!? Can anyone help? Could it be the pre cat lambda sensor at fault? Please help!
PostPosted: Wed Jul 01, 2015 1:46 pm Up
I would try your precat lambda sensor. Had this issue on my car a few years ago. What engine and year car is it.
dmsempire
PostPosted: Wed Jul 01, 2015 1:52 pm Up
hi, thank you for your message, it's a 2001 51 plate, 1.1 engine, from the looks of it it never had the Pre car sensor replaced. It's covered 125k miles.
PostPosted: Wed Jul 01, 2015 5:15 pm Up
It's easier if you put what the codes mean.
P0110 IAT Circuit Malfunction
P0300 Random Misfire
P0170 Fuel Trim Malfunction (Bank 1)
If the engine has air intake temperature problem, then that can cause the misfire. The unburnt fuel from the misfire will cause the O2 sensor to show a fault.
Check cylinder compressions and get a sniff test done. Any sign of coolant in the oil or oil in the coolant?
Also worth checking the wiring looms and connections.
This is the third TU lump hat has shown these symptoms in the last week and the other 2 have been head gasket failure.
The only problem is that fault codes only point in the possible direction of the fault and item that could be causing an issue. PP was showing on mine air intake temp, inlet manifold pressure, coil pack and injector. New head gasket solved all those. www.206info.co.uk/Foru...63619.html
dmsempire
PostPosted: Thu Jul 02, 2015 12:52 pm Up
No sign of oil in the coolant or coolant in the oil, not burning coolant, not burning oil... I'll have a compression test or sniff test done, but you're probably right and it's the head gasket Sad
