Online Now [358]:
Visitors: 357
Today: 46549
Total: 139055423
Forums › The Car › 206 Problems › Damp smell from blowers
Pugpug77
PostPosted: Fri May 06, 2016 7:05 am Up
Hi when using the blowers there's a putrid damp smell any idea what it could be? Where to start looking?
PostPosted: Fri May 06, 2016 11:27 am Up
When was the last time the pollen filter was replaced?
Pugpug77
PostPosted: Sat May 07, 2016 12:13 am Up
Less than 2 weeks ago just after it passes it's MOT it was serviced
Deano69
PostPosted: Sat May 07, 2016 8:13 pm Up
don't mean nothing...
check it yourself must be the easiest item to replace on the whole car Smile
gazza82
PostPosted: Tue May 10, 2016 4:45 am Up
And they showed you the old one of course? Confused
Pugpug77
PostPosted: Tue May 10, 2016 9:10 am Up
Should have said we service the cars ourselves
PostPosted: Wed May 11, 2016 1:09 am Up
How long has the smell been there? Is it any different if the heater is set to hot or cold? Is it any different if you have it set to direct air to the windscreen, centre vents or foot warmers? What's the coolant level like in the expansion bottle? How old's the car? Does it have aircon?
I would have said it was the pollen filter, but since you say you've already changed that you need to start investigate further.
Deano69
PostPosted: Wed May 11, 2016 1:00 pm Up
Maybe there is water getting in thru the bulkhead...
are the carpets under the dash damp at all ?
Pugpug77
PostPosted: Thu May 12, 2016 6:53 am Up
The passenger footwell was wet after the heater matrix leaked it's been replaced and the footwell has been shampooed
The cars a 2008 the smells always been there since we bought it 2 months ago the water level is good too
Haven't noticed a difference in smell when blowers on different setting but will pay further attention to this
Car does have air con that isn't cold a clean and recharge are on my to do list!
