Just an update - can put this one in Problem Solved section if required.
Got the wiring loom from a rear door (with a speaker) and transplanted same into my replacement n/s/r door that was missing a speaker. As the car was originally wired for speakers in the rear, this was the only modification I needed to do and it all works ok. I used a Pioneer DEH-X5800BT head unit, Pioneer TS-G1732i co-axial speakers for the front and Pioneer TS-G1332i co-axial speakers for the rear. It's not gonna blow the doors off or anything but it's still a significant improvement over the stock system and the Bluetooth is really useful for phone based music and calls. Steering wheel controls also work using this adapter lead (http://www.ebay.co.uk/itm/PIONEER-PEUGEOT-206-307-Steering-Wheel-Stalk-Adaptor-/350268992937?hash=item518da8ada9) although you'll need to check which one you'll need (mine's a 2002 model 206 1.1 LX).
I got a new battery prior to replacement and all seems to be working fine (using the "soft boot" procedure outlined on the forum). The only problem is that I've lost the clock/track/temp display in the dash, but can get most of this on the stereo anyway, so am reasonably content all round.
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
