Latest: lio94
Overall: 17181
Online Now [177]:
Visitors: 176
Today: 49290
Total: 141067583
Forums › The Car › 206 Problems › 206 stalls at lights
Geforce
PostPosted: Wed Aug 19, 2015 12:49 am Up
Hi all I have a 2000 206 1.4 8v. I have a problem where at traffic lights the idle will jump up and down then when I'm ready to pull away the car stalls and sometimes trouble starting up again.
I do have the bujicord coil pack but not Bosch spark plugs
Any help please
PostPosted: Wed Aug 19, 2015 2:35 am Up
Does it do the same at other junctions or just traffic lights?
Geforce
PostPosted: Wed Aug 19, 2015 3:46 am Up
Mainly at traffic lights, Judders when trying to pull away
Geforce
PostPosted: Thu Aug 20, 2015 12:39 am Up
Update: stalled at lights, took six attempts to restart Sad
PostPosted: Thu Aug 20, 2015 1:26 am Up
Next time see what happens with some throttle applied.
Geforce
PostPosted: Fri Aug 21, 2015 3:09 am Up
Ok, it also feels like the car is speeding up by itself
darthvalkyr
PostPosted: Thu Sep 03, 2015 1:44 pm Up
Get the Bosch plugs!! I have the same engine and NGK plugs were fitted when I got it. Low rev range was awful and it stalled a lot. The idle was unsteady too. The NGK plugs work badly with the Bougicord coil pack and Magnetti Marelli ECU, which causes misfires and loss of low rev power.
I swapped the plugs for Bosch, changed the air filter and fuel filter and it is a completely different animal. Guessing if you give it some gas before you try and move it pulls off OK, but not from idle?
