Hi I was wondering if anyone has any idea about
My problem which is the esp button doesn't
Do anything the light on the button is off
And there is no warning lights on dash board
When i press the button still nothing happens
I have changed the fuses which made no difference
Please help
Mick778
Please help
Mick778
Basic sanity check since you don't mention it - you've checked that the connector is properly attached at the back of the switch?
Have you checked that the switch actually physically works, ie ohm-meter switches between 0 and infinity across the appropriate terminals as activate/deactivate the switch?
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
