Online Now [53]:
Visitors: 52
Today: 628
Total: 116736914
Forums › The Car › 206 Problems › peugeot sw 1.4 stalling and sometimes jumpy
sandy2000
PostPosted: Wed Jul 29, 2015 9:10 am Up
has anyone ever solved this problem,my car has been stalling and jumpy for a while had 02 sensor fitted made no difference no lights are on no fault codes are showing it is going back to the garage again 2morrow hopefully it will be fixed but not holding my breathe
darthvalkyr
PostPosted: Thu Sep 03, 2015 1:58 pm Up
Make sure spark plugs are not NGK. Use Bosch plugs as NGK plugs cause this kind of issue.
Might be worth changing air filter and fuel filter too. Would also consider using Redex to make sure fuel system is clean.
