Latest: tebas93089
Overall: 17179
Online Now [332]:
Visitors: 331
Today: 3327
Total: 138523127
Forums › The Car › 206 Problems › Removing the airbag
Removing the airbag
Squashedfish
PostPosted: Sun Oct 11, 2015 1:32 am Up
Airbag removal - I am looking to remove the airbag from my GTI, all the things I have read says there should be a hole at the bottom of the steering wheel at the back, mine doesn't have this, it has a slot at the 3 o'clock position, is this the same thing?
PostPosted: Sun Oct 11, 2015 3:50 am Up
The airbag removal process is different depending upon if your car is pre-plexed or multi-plexed.
Squashedfish
PostPosted: Sun Oct 11, 2015 4:56 am Up
Ah ok, thanks.
gazza82
PostPosted: Mon Oct 12, 2015 5:54 am Up
Pre-mux it is screwed on so you have two round holes, mux is clipped on so you have two rectangular slots.
Either way, disconnect the battery and leave for about 10-15 mins before you try anything .. that discharges the system ...
