Latest: Kifi69
Overall: 17183
Online Now [421]:
Visitors: 420
Today: 83223
Total: 144543004
Forums › The Car › 206 Problems › What Power Steering Fluid?
Bernie70
PostPosted: Thu Nov 05, 2015 2:59 am Up
Hi, I'm new to the forum and will firstly apologise if this has been posted before.
I've got a 2005 Peugot 206 and need to top up the Power Steering fluid. Haynes Manual advises to use Total Fluide LDS but the only stuff I can find online is suitable for Citroens??
Obviously don't want to use anything that's incompatible with my car so does anyone have any ideas as to where I can get my hands on this? (Glasgow area)
Thanks for your help.
David1156
PostPosted: Thu Nov 05, 2015 3:49 am Up
If it's OK for citroens it should be fine for peugeots too as they're from the same manufacturer (to some extent)
Current: Albi Blue Clio 197
Bernie70
PostPosted: Tue Nov 24, 2015 5:10 am Up
Many thanks for your help.
Motorracingbruce1980
PostPosted: Tue Nov 24, 2015 5:29 am Up
ATF Dexron II is the grade you require
careful as some Citroens use LHM!
Project China Blue 206 GTI
gpvecchi
PostPosted: Tue Nov 24, 2015 3:14 pm Up
No guys, LHM was for old Citroen with hydraulic suspensions/steering (Xantia, XM, BX...); LDS is for electr-hydraulic steering pumps (308 etc.).
All Pug mechanical steering pumps use ATF/ATX red fluid (the same used in most automatic gearboxes).
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
