Latest: Beduff1977
Overall: 17134
Online Now [251]:
Visitors: 250
Today: 101878
Total: 109557935
Forums › The Car › 206 Problems › In of Need help for my A/C problem
Aminu
PostPosted: Sun Nov 08, 2015 2:40 pm Up
Aloha to all to all viewing this
The air condition of my pug206 is consuming a lot of gas. I went to the A/C specialist and they tell me all is well with it, no leakages found but it always run out of A/C gas every one and a half month.
Do any one experienced similar fault and come to my rescue please.
mtempsch
PostPosted: Sun Nov 08, 2015 11:15 pm Up
Don't know of anything else that'd cause an A/C to loose pressure like that other than a leak...
Has UV dye been added to the system? Have you/they looked around using an UV light?
Did they pull a vacuum on the system, and test by letting sit for a while to make sure it's held?
Silvermetallic 2004 206 RC
PostPosted: Tue Nov 10, 2015 2:20 am Up
Well to fix this problem,I'm going to ask you a question,and your answer will be the fix of this,according to what you said,the A/C gas only last a month an half,right?
Is that with you using the A/C on daily basis or you discover it's not working when you need it?
Waiting for your answer.
Aminu
PostPosted: Tue Nov 10, 2015 4:51 pm Up
Probably my A/C is always on as far as am in the car.
Deano69
PostPosted: Wed Nov 11, 2015 12:53 pm Up
always on or not... it should last much longer then that, you must have a leak.
Get the leak tracing dye put in it.
PostPosted: Thu Nov 12, 2015 8:19 am Up
You need to replace the A/C compressor as it's the one that leak the gas when it's working.
Aminu
PostPosted: Sat Nov 28, 2015 1:19 pm Up
Thank every one for all the advices. the problem is now quarantined.
