Latest: Beduff1977
Overall: 17134
Online Now [557]:
Visitors: 556
Today: 61323
Total: 108693574
Forums › The Car › Request a how-to › Any way of turning traction control off? 1.4 16V SE?
Forum IndexRequest a how-to
JackCharlesRoss
PostPosted: Sun Nov 15, 2015 12:30 pm Reply with quote Up
Just wondering if there is any way to turn traction control off in an se 1.4 16v? Thanks!
PostPosted: Sun Nov 15, 2015 5:27 pm Reply with quote Up
You have ESP? Im pretty sure only 180s have ESP
PostPosted: Mon Nov 16, 2015 12:03 am Reply with quote Up
Ive seen ESP fitted on a ET3 before, someone must have ticked the option box when originally ordering the car.
FWIW: Late GTI have ESP fitted as standard & the GTI HDI has it to.
PostPosted: Mon Nov 16, 2015 5:05 am Reply with quote Up
Any petrol with motorised throttle body has esp doesn't it?
PostPosted: Mon Nov 16, 2015 6:55 am Reply with quote Up
GTI 180, GTI HDI & late GTI had it as standard, for the rest its optional extra.
You do indeed need the motorised throttle body to have ESP on a 206.
JackCharlesRoss
PostPosted: Tue Nov 17, 2015 1:49 am Reply with quote Up
I can confirm that my car does has ESP Smile
PostPosted: Tue Nov 17, 2015 3:08 am Reply with quote Up
Unless its going on a track OR its stuck in snow the ESP is best left switched ON.
PostPosted: Tue Nov 17, 2015 6:46 am Reply with quote Up
There should be a button on the dash to turn it off for a short while, or your could deconfiqure it via pp2000
JackCharlesRoss
PostPosted: Tue Nov 17, 2015 11:53 am Reply with quote Up
Okay, Thanks Addaz, Never used pp2000 but i know what it is, Could you inform me of the correct cables i will need to use it on my laptop? Thanks
PostPosted: Tue Nov 17, 2015 4:25 pm Reply with quote Up
If it has esp as standard the button will be down by the ignition, next to the airbag key. Hold it down to turn it off.
  Quick Reply
Username:
Message:
Quote the last message
