Forums › The Car › 206 Talk › Green moss? |
Posted: Wed Nov 25, 2015 10:30 am |
Just giving the car a bit of a clean today when I noticed under the rear window glass on the hatch is what looks like green moss. Is there anyway I can get rid of this without having to take the back screen out. It looks as thogh there has been water ingress between the glass and body (not wet in boot).
Steve.
Posted: Wed Nov 25, 2015 12:54 pm |
Paintbrush will reach into the gap to remove it.
