Latest: jackrox1992
Overall: 17186
Online Now [720]:
Visitors: 719
Today: 41957
Total: 147773394
Forums › The Car › 206 Problems › Peugeot 206 Hatchback Outer Door Trim fix ?
CJH20
PostPosted: Thu Nov 19, 2015 9:25 am Up
Hello
I have noticed one of the clips on my Peugeot 206 xsi hdi outer door trim has broken and the end of the trim is off , it looks ugly like that .
Is it easy to get the trim off to replace a clip ?
I really could do with a how to , as I really don't want to mess this up .
It looks easy enough , but can anyone help please .
Thanks all .
Col .
Motorracingbruce1980
PostPosted: Thu Nov 19, 2015 9:50 am Up
The trims just pull off but the clips go brittle and do snap. They are cheap to buy from the dealer though and they are normally in stock.
The trim itself if damaged can be replaced with after market ones, the fit isn't quite as good but you have to look close.
Project China Blue 206 GTI
CJH20
PostPosted: Thu Nov 19, 2015 10:28 am Up
Thanks Motorracingbruce1980
The trim look fine , but one clips head is sheared off ! I can get those and have ordered some . I also have a set of plastic trim removers which might help pop the trim off .
Will let you know how it goes . Wink
