Latest: tbafonso
Overall: 17130
Online Now [313]:
Visitors: 311
Members: 1
Today: 41159
Total: 104009046
Forums › The Car › 206 Problems › 2 Button fob key will not synchronize - 2006 sport 206
Go to page Previous  1, 2
duffy1807
PostPosted: Fri Dec 04, 2015 10:53 am Up
mtempsch wrote:
duffy1807 wrote:
Does anybody know how I can find out if my car is a 434Mhz without buying a new key again? Or is their anything else that could be stopping me from programming the remote central locking?
thanks
Haven't had to mess with it myself, but from I've read here on the forum: You need the same model/version of the circuit board that the original key has/had. And there has apparently been 4 variants used by Peugeot, see Macca's post in the linked thread.
Thanks,
will have a read up on this, much appreciated by the look of things ill probably need to go the dealer :/ - will see what happens
Thanks again pal
AJAC
PostPosted: Mon Feb 22, 2016 8:06 am Up
Hello, The main thing is that there are basically parts to a key The Shaft that has to be cut to shape and the Transponder for the immobilizer. The Transponder will have a code. If you have a Non remote key the Transponder may be a different shape but hold the Transponder code you need, But if it the correct shape that can be moved to a Remote Key Fob and work straight away. The Remote is the 3rd part and works independently of the other and has a PCB and that has it's own code and has to be with the car to it
Page 2 of 2
