Latest: Beduff1977
Overall: 17134
Online Now [366]:
Visitors: 365
Today: 171225
Total: 108507360
Forums › The Car › 206 Problems › Headlights
Headlights
Snoopy07057569
PostPosted: Thu Dec 03, 2015 12:37 am Up
Hi, new to site, I have a 51 reg 1.4hdi with the old style lights and a friend had an 04 with crystal lights he was scrapping so I had the front and back lights, my problem is now when fitted everything works fine apart from when I engage main beam I lose dipped beam! I only get one or the other! Any ideas
Cheers
PostPosted: Thu Dec 03, 2015 12:45 am Up
We need to know if your 206 is non plexed OR multiplexed, 51 plate is the change over point.
The way to get the crystal headlights working correctly is different.
Non plexed you simply change the headlamp stalk.
Multiplexed you use Peugeot Planet software & change a setting in BSI configuration.
