Latest: tbafonso
Overall: 17130
Online Now [222]:
Visitors: 221
Today: 56865
Total: 103642643
Forums › The Car › 206 Problems › What on earth are these wires for!? :(
hussnainh8
PostPosted: Mon Dec 07, 2015 9:11 am Up
Hi,
Can anyone tell me what are these 4 connectors used for?
I have tried the male connector to the headlight connector but 1) the battery drains itself after 3-4hours and 2) I have no idea what the wires do because the headlights already have power from a different source.
As for the female connectors.. I do not know why they are not connected where they should be connected as the car was like this when first bought.
www.dropbox.com/s/v6rr...n.jpg?dl=0
www.dropbox.com/s/26ow...n.jpg?dl=0
Motorracingbruce1980
PostPosted: Mon Dec 07, 2015 9:44 am Up
Front fog wiring and Headlamp level adjustment I think
Project China Blue 206 GTI
PostPosted: Mon Dec 07, 2015 11:11 am Up
The grey 3 pin connector is for the crystal twin H7 headlamp.
The grey 2 pin connector is for the front fog lamp.
What headlamps are currently fitted to the car?
gazza82
PostPosted: Mon Dec 07, 2015 11:43 am Up
If you look at the second picture you can see the empty headlamp socket on the back of the headlamp ...
so I would guess they are the standard single H4 bulb headlamps and this car has the multi-purpose loom ...
hussnainh8
PostPosted: Mon Dec 07, 2015 5:29 pm Up
The car has the standard H4 headlights but the H4 headlights also have a connector on the back of them where the 3 pin wire can connect too.. I did this and it just drained the battery instead :l and my 206 doesn't have front fog lights.
