Latest: jackrox1992
Overall: 17186
Online Now [587]:
Visitors: 586
Today: 26131
Total: 148197258
Forums › The Car › 206 Problems › Door check strap
Door check strap
AmyRou
PostPosted: Tue Dec 29, 2015 2:41 pm Up
Hi, I've just replaced the drivers side door check strap, the single securing bolt in to the 'A' frame/pillar has sheared off. It looks like a captured nut within the 'A' frame/pillar, is it accessible to replace the nut?
Many thanks Amy Rolling Eyes
PostPosted: Tue Dec 29, 2015 2:49 pm Up
As far as im aware no, a reweld is required
AmyRou
PostPosted: Wed Dec 30, 2015 1:09 pm Up
Ok thanks
PostPosted: Sun Jan 03, 2016 6:00 pm Up
Drill and re-tap the thread a slightly larger size. Drill out the check strap hole to suit the new bolt. Job done.
PostPosted: Mon Jan 04, 2016 3:36 pm Up
Rivnut Wink
Technically you need the tool to fit it BUT you can fit a Rivnut using washers & screwing a bolt in to squash it in to position.
