Online Now [101]:
Visitors: 100
Today: 14042
Total: 104987045
Forums › The Car › 206 Problems › Rear Light cluster
Rear Light cluster
keywest
PostPosted: Sat Jan 23, 2016 7:12 am Up
My Driver side rear light cluster does not come on, when you put your lights on then if you bang it, it comes on.
Does not happen every time, just every now hen ? any ideas
Its a 53 plate GTI 180
Cheers
James
mtempsch
PostPosted: Sat Jan 23, 2016 8:53 am Up
Cheers
James
Affecting all the lights? ie rear, brake, indicator, and reverse all remain off until banged? If so then likely the ground connection.
If only the rear light then could be the bulb, connection between bulb and bulb holder, power, plug to light, wire to plug...
Simplest first try would be to replace the bulb and see if behaviour improves...
If not start by verifying power at the appropriate pin in the plug while wiggling the wire. Then at the center pin in the bulb holder while wiggling the plug. Look at contacts, bulb holder etc for any corrosion.
When you insert the bulb in the holder, make sure the center contact is springy and puts pressure on the bulb contact as the bulb moves slightly up into the locked-in position
Silvermetallic 2004 206 RC
keywest
PostPosted: Sun Jan 24, 2016 5:16 pm Up
Thank you and its just the maker light that does not work, after a bang all good, lol All other lights work ok
