Latest: lio94
Overall: 17181
Online Now [286]:
Visitors: 285
Today: 21365
Total: 142064870
Forums › The Car › 206 Problems › Strange rattling noise from gear stick (linkages?)
FrankAteMyName
PostPosted: Mon Jan 25, 2016 4:54 am Up
I've just got anothr 206. A 2003 1.4 8v GLX. It drives reasonably well considering the 93k on the clock. Today on the way to work I noticed that at high revs (Around 3k) there was a rattling noise. It sounded like a rattling interior trim panel. My passenger grabbed the gear stick and it stopped until he released it.
So my question is, what would cause this? I'm naturally assuming gear linkages as there is a little play in the gear stick when it is in gear (probably only a cm or so). What steps would need to be taken to fix this?
Thanks in advance.
FrankAteMyName
PostPosted: Tue Jan 26, 2016 3:03 am Up
I guess the noise could probably be better described as a mechanical buzzing. Just 2 components vibrating against eachother.
My cars:
206 Urban 1.4 8v 3dr '56 - China Blue - 70k Miles - Climate control retrofit, cruise control retrofit - Dead (Breaking)
206 GLX 1.4 8v 3dr '03 - 100k Miles - Obsidian Black - Black masked headlights + front fogs, Faster sunroof, Colour matched exterior trim - SOLD
206 2.0 GTI 138 '03 - 58k Miles - Onyx Black - 17" 180 Alloys - Current
206 2.0 GTi 138 '03 - 120k Miles - China Blue - New Track Toy (ON THE WAY)
PostPosted: Tue Jan 26, 2016 11:09 am Up
You might have a wear out gearbox or maybe engine mount bush,they usually when broken make the engine sound travel to the compartment.
FrankAteMyName
PostPosted: Wed Jan 27, 2016 6:22 am Up
Hi, thanks for your help.
How would I best go about diagnosing the issue?
My cars:
PostPosted: Wed Feb 10, 2016 2:00 pm Up
sorry for my late reply,but best way to diagnose this,is by having a look at it using a lift,or you can let someone put first gear on,and have hand break on,and try to move the car forward without moving of course,and watch the engine movement,and also do the same with Reverse,if the engine move so much,then you need to replace it.
FrankAteMyName
PostPosted: Thu Feb 11, 2016 9:05 am Up
Thanks for your reply. Sadly the car had a less than ideal meeting with the central reservation before I had chance to fix this. RIP little puggy. On the bright side I've got a garage full of spare parts now! Very Happy
My cars:
Sim
PostPosted: Fri Feb 12, 2016 5:02 am Up
Sorry to hear that mate, hope everyone's fine; and good you're looking at the bright side! Smile
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Sat Feb 13, 2016 4:45 am Up
Sorry to hear that :(,hope all is well with you.
