Posted: Thu Jan 07, 2016 9:53 am |
Hi bought my pug a year ago with no manual. Now im stumped as to where the passenger fusebox is?? as my radio is deceased and also multi funtion display lights are dim. thnks in advance
Posted: Thu Jan 07, 2016 12:22 pm |
Remove the panel below the steering wheel and you'll find the fusebox and BSI unit. A 2p coin turns the screw pretty easily.
Posted: Thu Jan 07, 2016 1:45 pm |
thanks macca but the schematic on this site says the fuse is located in the passenger fuse compartment not the driver one.
Posted: Thu Jan 07, 2016 2:30 pm |
| jimjammy wrote: |
| thanks macca but the schematic on this site says the fuse is located in the passenger fuse compartment not the driver one. |
It's the same thing. Passenger compartment fusebox as oppose to the engine bay fusebox.
Posted: Thu Jan 07, 2016 4:08 pm |
ok thats sucks as the schematyic shows radio/ multi function at F18 and mine doesnt have an F18. stumped
Posted: Thu Jan 07, 2016 4:19 pm |
Posted: Fri Jan 08, 2016 6:16 am |
cheers macca. thanks for help
Posted: Tue Feb 16, 2016 8:37 pm |
Hello. Low MDU display will be bulbs, There are 3 Capless 1.2 Watt bulbs. Check on You tube how to remove MDU on a 206, Very easy. Go to Halfords you might a well change all 3, 2 of mine were blown, Could not see left hand side or middle section
