Latest: jackrox1992
Overall: 17186
Online Now [890]:
Visitors: 890
Today: 80362
Total: 148844402
Forums › The Car › 206 Problems › Ash: Annoying Rattle
Ash
PostPosted: Sat May 14, 2011 3:02 am Up
Right guys, I'm fed up with this fecking rattle. It's coming from the passenger side pillar/door area..
I'v stripped it out 5 times trying to find it with no luck. Every stupid thing has deadening on it. So can someone give me ideas on where to look?
It's basically coming from where the door meets the pillar but I really have no idea where to look now..
Yes, I know it's a 206 and it rattles like a b***h but yesterday, went for a drive at 10PM just after it had rained and the car was so quiet, I would have thought I was in the Audi.. bar that stupid rattle every few seconds!
Cheers for any input in advance Smile
Ash
PostPosted: Sat May 14, 2011 3:04 am Up
Do u mean door catch side? Could be similar fault to the boot catch rattle ?
tagget
PostPosted: Sat May 14, 2011 3:06 am Up
mine does that! plus when i have my sub on it rattles my boot lid lol
ukskater01
PostPosted: Sat May 14, 2011 3:08 am Up
Mine does exactly the same, I haven't had a chance to look at it yet, when I do I'll let you know if I solve it
Does my head in too!
Ash
PostPosted: Sat May 14, 2011 3:11 am Up
Care to expand?
elcamino
PostPosted: Sat May 14, 2011 3:38 am Up
Ash
Have a look at door lock mount(hook)on pillar.it happens when door locks too tight.loosen 2 screws and push it 1 or 2 mm's outward then tighten them.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
seanbmx
PostPosted: Sat May 14, 2011 7:51 am Up
check strap maybe? mine had the same annoying rattle, turned out that my check strap was knackered, replaced it with a new one and i havnt heard it since
buy it, fix it, mod it
Ash
PostPosted: Sat May 14, 2011 8:23 am Up
elcamino wrote:
Ash
Already tried that but I'll try again.
It's a new one on the passenger side and the noise is definitely not coming from there.
Jaffamoments
PostPosted: Mon May 16, 2011 2:44 am Up
I have a VERy annoying rattle coming from the boot...can anyone advise how to fix it???
Ashley's Firedance
i1229.photobucket.com/...s/car2.jpg
Lecktorious
PostPosted: Mon May 16, 2011 1:03 pm Up
Trade Rating: +59
Replace the boot latch, the rubber stop gets worn with age and rattles like a pig.
'98 Nile Blue 306 GTi 6
Rob2859
PostPosted: Mon May 16, 2011 2:05 pm Up
It has a rubber stop?
Lecktorious
PostPosted: Mon May 16, 2011 2:19 pm Up
Trade Rating: +59
Look at the latch and look where the lock meets it.
Rob2859
PostPosted: Mon May 16, 2011 5:26 pm Up
I have no such thing Very Happy
owlinbrum
PostPosted: Fri Dec 23, 2016 12:06 am Up
This is very useful. I'm not sure about the latter posts on stops, but I had the same intensely annoying knocking rattle around the door latch/catch pillar area.
I changed the check strap, as that had slight play in the hinge pin. It didn't resolve it, but the answer seems to have been putting insulating tape around the catch on the door pillar. As with the boot rattle previously mentioned.
Great there is so much here for reference and so many in the know.
Thanks.
