Online Now [393]:
Visitors: 392
Today: 48654
Total: 145011111
Forums › The Car › 206 Talk › GTi Injectors
GTi Injectors
Forum Index › 206 Talk
leigh_boy
PostPosted: Tue Feb 15, 2011 4:36 am Up
are the 138 bhp and 180bhp injectors the same? i got a fault with injector 1 but don't know if there the same as a 180
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
PostPosted: Tue Feb 15, 2011 7:03 am Up
Apprently the 180 injectors are different.
leigh_boy
PostPosted: Tue Feb 15, 2011 9:29 am Up
hmm , would 180 injectors work on a 138???
*DEAD*206 Gti 138
PostPosted: Tue Feb 15, 2011 12:59 pm Up
Pointless unless you've got serious modifications.
leigh_boy
PostPosted: Tue Feb 15, 2011 1:13 pm Up
i don't want it for any power inprovments just a case of what i can get hold of cheapst
i dont bother with mods not my style id rather just buy a faster car.
i have my bikes for speed
*DEAD*206 Gti 138
Lee180
PostPosted: Tue Feb 15, 2011 1:25 pm Up
180 injectors are bigger, im pretty sure. but dont take that as a biblical
Originate, don't duplicate.
PostPosted: Tue Feb 15, 2011 1:27 pm Up
even if they physically fit you will need a remap to get the flow correct.
and not to mention you can't just fit 1 180 injector with 3 138 injector in line. Very Happy
leigh_boy
PostPosted: Tue Feb 15, 2011 1:36 pm Up
ok to the remap didnt really cross my mind, and i wouldnt replace just 1 i would do the lot Smile
*DEAD*206 Gti 138
PostPosted: Tue Feb 15, 2011 1:53 pm Up
Will physically fit but the flow rate will c**k things up.
intermilan206
PostPosted: Tue Oct 29, 2013 11:37 am Up
bringing this thread up again...
what is the cc of 138 and 180 injectors?
206 1.6L 16V XT - RIP
206 GTi 138++
Koni Sport dampers, H&R springs, GTi180/RC rear axle and front ARB. Sparco strut bar, Yokohama AD08R tyres, Raceland 4-1 manifold, Remus backbox, Magnaflow sport cat, Catcams Fast Road cams, Unichip Q piggyback ECU, Pipercross VIS kit, Vibra Technics mount kit, 283mm Brembo Max front discs and rear discs, Ferodo DS2500 front & rear brake pads, Goodridge brake hoses, 307 23.8mm master cylinder, brake servo and calipers; Quaife LSD, AST adjustable top mounts and 206 WRC rear spoiler (just can't resist it).
Postpone / KIV / Coming soon: Mocal oil cooler kit.
Removed: Combrake top mounts.
206gt160
PostPosted: Sun May 25, 2014 3:04 pm Up
Bump
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
intermilan206
PostPosted: Mon May 26, 2014 12:08 am Up
GTI138
▪ Static rate to 3 bar, n-heptane unit [g / min.]: 141
▪ Resistance [Ohm]: 14.5
Part number: 1984 E2
GTI180
▪ Static rate to 3 bar, n-heptane unit [g / min.]: 187
Part number: 1984 F3
Found it out almost a month ago.
206 GTi 138++
206gt160
PostPosted: Fri Feb 13, 2015 5:12 pm Up
Yet to remap mine and the 180 injectors have been fine, no engine management lights or erratic jumping rev's.
PostPosted: Fri Feb 13, 2015 5:48 pm Up
That doesn't mean everything is right.
206gt160
PostPosted: Fri Feb 13, 2015 5:51 pm Up
Very true, who would you recommend to remap when I get it booked in.
