Latest: tbafonso
Overall: 17130
Online Now [307]:
Visitors: 307
Today: 2062
Total: 103932504
Forums › The Car › 206 Problems › Peugeot 206cc Anti Pollution fault
Nidge
PostPosted: Tue Feb 09, 2016 3:58 am Up
Hi,have a problem with my Peugeot 206 cc 2l.Anti Pollution fault comes up after driving around 10-15 miles and cylinder 4 starts misfiring.Comes up with the fault code p0204 when plugged in.Also my temp in the middle display started being faulty recently and showing around -20.Could this be the cause or just totally coincidence?Any help appreciated,cheers
gazza82
PostPosted: Tue Feb 09, 2016 4:51 am Up
I don't think the door mirror sensor is linked to the engine ecu just the BSI for A/C etc.
External air temps are picked up by the Air Flow Meter.
If you google "Peugeot P0204" some sites suggest it could be the injector going open circuit when warm. No 4 should be the one by the belts, so swap it with no 2 or 3 and see if problem comes back.
Nidge
PostPosted: Tue Feb 09, 2016 5:44 am Up
Hi,thanks for that.Was going to be my plan of action but was just curious of the temp thing maybe causing it.Cheers for clearing that up Smile
