Latest: Beduff1977
Overall: 17134
Online Now [607]:
Visitors: 606
Today: 244
Total: 109171381
Forums › The Car › 206 Problems › Front windscreen replacement
tommyb32
PostPosted: Thu Feb 11, 2016 8:32 am Up
I need of a be windscreen and seen on for £30 near me. I have an 03 gti 180 but the windscreen is from a 206cc. Will this fit my car? Also it has light/rain sensor does this effect the type of windscreen I need?
tommyb32
PostPosted: Thu Feb 11, 2016 8:33 am Up
Auto correct fail * I'm in need of a new...*
gazza82
PostPosted: Thu Feb 11, 2016 8:35 am Up
Think a CC is different to hatch .. but maybe someone can confirm. I think there is a specific screen with sensor .. so you have to get the right one ... don't you have screen cover on your insurance?
Reusing a screen may not be a good idea ... they are not easy to remove without chipping them and this will just weaken it ...
tommyb32
PostPosted: Thu Feb 11, 2016 8:58 am Up
I can use my rain sensor but not sure if it has to be a compatible windscreen. The difference I can see is on mine with the sensor there is some black film? That extends behind the mirror a tad more. If anyone can get what I mean from that lol
PostPosted: Thu Feb 11, 2016 2:36 pm Up
I'm sure the CC screen will be longer....
PostPosted: Sat Feb 13, 2016 3:56 am Up
The CC front windscreen will not fit the hatch,if your car got light/rain sensor ,you need to get a windscreen the is the same as yours so that you have the original look,and hide sensor and wiring behind the black film.
tommyb32
PostPosted: Mon Feb 15, 2016 2:08 pm Up
guys still looking for a front windscreen! I have found one from a 207 it has rain sensor ect.... but will a PEUGEOT 207 2006-2012 (<---Advertised as), fit a 2003 206gti 180?
tommyb32
PostPosted: Mon Feb 15, 2016 2:09 pm Up
here it is..
www.ebay.co.uk/itm/191...#vi-ilComp
tommyb32
PostPosted: Mon Feb 15, 2016 2:16 pm Up
or a standard 206 gti, will that fit?
gazza82
PostPosted: Mon Feb 15, 2016 3:10 pm Up
206 hatch will fit a 206 hatch ...
Why not claim off your insurance?
tommyb32
PostPosted: Mon Feb 15, 2016 3:24 pm Up
3rd party mate
gazza82
PostPosted: Mon Feb 15, 2016 5:26 pm Up
The only time I asked it wasn't much cheaper the fully comp and a lot less risky.
Still a gti screen should fit but my concerns over a 2nd hand screen still stand ...
Sim
PostPosted: Mon Feb 15, 2016 6:06 pm Up
The black dotted mask on windscreen is to hide wiring and probably prevent extra light intake.
Rain/light sensor lenses will have a clear rectangular cut-out into which they will be glued with special translucent and particle-free glue.
The sensor itself clips onto those lenses, and can be swapped out easily.
Your best bet is a windscreen with rain sensor (at least mask and undamaged lenses) from a 206, I wouldn't risk it for biscuit.
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Tue Feb 16, 2016 4:07 am Up
Make a few phone calls and see how much it will cost for a new screen supplied and fitted. I paid £90 from a local independent fitter.
The screen on ebay is secondhand and £75 (and I highly doubt a 207 screen will fit in a 206). Add another £30-£40 on for fitting, and that's if you can find someone to fit a secondhand screen.
Is it worth scrimping on safety?
