Online Now [313]:
Visitors: 312
Today: 30297
Total: 142298793
Forums › The Car › 206 Talk › HDI 2.0 Dturbo - Crank pulley
13MD
PostPosted: Thu Feb 11, 2016 1:19 pm Up
Could someone tell me what's the best way to remove the crankshaft pulley on my car. I don't have a impact driver.
I was told to put it in 5th gear to stop it moving but when I had it in gear and tried to rotate it anticlockwise the pulley rotated.
Thanks,
southwestchap
PostPosted: Fri Feb 12, 2016 5:37 am Up
In gear and foot on the brake, might need to jump on your breaker bar.
Some can be tight as, especially if the previous spanner monkey has covered the bolt in threadlock.
13MD
PostPosted: Sun Feb 21, 2016 7:32 am Up
Hello, had it in gear and someone put their foot on the brake for me.
Pulley was still spinning when trying to remove.
Is both the flywheel and cam supposed to be locked before removing the crank pulley? I was told not to in case the pin snapped off inside while trying to remove the bolt.
PostPosted: Sun Feb 21, 2016 11:26 am Up
You need to lock the crankshaft. Not sure how you do I on that engine though.
PostPosted: Sun Feb 21, 2016 11:32 am Up
www.406oc.co.uk/viewto...f=1&t=8229
Good method on here, They say you can loosen the bolt by placing your socket over it, resting the wrench against the car and quickly turning the engine over once.
southwestchap
PostPosted: Mon Feb 22, 2016 6:50 am Up
Be careful when locking the crank (hole in behind the starter) only takes an 8mm allen key or such like. Would't stand up to someone jumping on the breaker bar. Then it can be a gearbox off job to remove the fly, I've had to do that for someone before.
PostPosted: Mon Feb 22, 2016 8:13 am Up
What gear was it in?
13MD
PostPosted: Wed Feb 24, 2016 4:54 pm Up
Have it in 5th gear.
Battery is dead at the moment but if nothing else works I'll give it a go.
Has anyone got a photo of where to lock off the flywheel? I've seen various pics that each one looks different from the other.
This is my view from under the car.
PostPosted: Thu Feb 25, 2016 3:20 am Up
Pretty sure it's on top of the box. On my old gti is was behind the box though. They both share the be4 box so you might have to check.
13MD
PostPosted: Wed Mar 09, 2016 11:53 am Up
Found it. As you can see in the pic there is a yellow tube (no idea how or where that came from it just lifted out) but it was in my way.
It was quite hard to get the pump out and the new one in due to the lack of space. Does anyone else jack there engine down for easier access? Think it mentioned not to in the haynes without removing other parts first.
Is the water pump gasket that comes with it sufficient or does anyone use any other forms of sealant along with the gasket?
