Posted: Tue Feb 09, 2016 10:29 am |
Ok so every time I turn left my oil and handbrake light comes on. I have checked my oil and brake fluid levels but they are fine... What is going on? I have a 1999 206 1.4 petrol. HELP ME!!!!
| | ![](images/spacer.gif) |
Posted: Wed Feb 10, 2016 10:47 am |
it better be checked,as you might have oil pressure sensor fault,and usually the handbrake light goes on if the brake fluid level sensor is faulty as well.
Posted: Wed Feb 10, 2016 1:33 pm |
Ok thanks do you think it will be expensive? And is it normal to happen only when I turn left?
Posted: Sat Feb 13, 2016 3:49 am |
not it not expensive,the oil pressure sensor brand new is cheap and you can fit it yourself if you know the basics.
