Latest: Beduff1977
Overall: 17134
Online Now [424]:
Visitors: 423
Today: 115948
Total: 107296694
Forums › The Car › 206 Problems › Multifunction Display Not Working
sagiterion
PostPosted: Tue Jan 12, 2016 11:55 am Up
Hi Every One,
I have just bought a Peugeot 206 1.4 XR S Edition 2005. It is a really well maintained car except one problem. The lights for AC/Heater control along with Multi function display are off. Every thing else is working perfectly fine but the lights are off.
Could you please help me by guiding me how to fix it.As I am new and this is also my first car.
Thanks In Advance
Motorracingbruce1980
PostPosted: Wed Jan 13, 2016 1:42 am Up
Its probably just the bulbs that Illuminate the unit that have blown and need replacing.
Project China Blue 206 GTI
sagiterion
PostPosted: Sat Jan 16, 2016 7:13 am Up
onHI,
Thanks for the information. Is there any thread or information where I can see how to change the bulbs?
mtempsch
PostPosted: Sat Jan 16, 2016 10:00 am Up
sagiterion wrote:
onHI,
This Howto shows how to change the colour of the upper display. At step 2 you have access to the bulbs at the back of the display (twist a 1/4 turn or so and pull out).
For the AC display you then need then loosen a couple of screws for the center part of the console and pull it off the clips, then another few screws to loosen the AC display itself. Screws will be of the Torx type, don't recall which size though.
Silvermetallic 2004 206 RC
PostPosted: Sat Jan 16, 2016 10:06 am Up
Torx 20 screws.
AJAC
PostPosted: Tue Feb 16, 2016 7:32 pm Up
Hello, Go to You Tube and Enter how to remove the Multi function Display unit Peugeot 206, I did mine last week and is very easy, Peugeot cannot tell you the correct Wattage, I replaced all 3 with Capless 1.2 Watt and get just the bulbs and use the original holders, Got mine from Halford's, I removed the unit and took it in as I did not know the Wattage. Unless you are going LED's in which case you want 0.2 Watt ones
Sim
PostPosted: Wed Feb 17, 2016 4:06 am Up
Oh cheers for that mate! I thought I had some blind spot in the eye as MFD left corner is dim Very Happy
Will sort that out and maybe de-tango as well once I'm at it:))
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
