Latest: Beduff1977
Overall: 17134
Online Now [198]:
Visitors: 197
Today: 65386
Total: 107377655
Forums › The Car › 206 Problems › HELP!!!
HELP!!!
Thehound84
PostPosted: Sun Feb 28, 2016 3:53 am Up
Rear axle, drum with abs..
I'm repairing the trailing arm bearings, have the axle off car, anti roll bar is out, can't budge the torsion bar at all, have tried the washer trick didn't work, tried blocks with a jack in between to push the arm off, no luck, beat the hell out of it with a big hammer all day, no joy, I don't have a slide hammer but I just know it won't work.. I was thinking of investing in a porta power but I'd only use it once, anyone have any idea apart from tying it to a tree and hooking the other end to a toe bar, should I cut it out?
PostPosted: Sun Feb 28, 2016 4:46 am Up
Pointless replacing the bearings, service exchange axle with a warranty is the way to go.
By the time play is noticed / found in the bearings. The damage to the stub axles has already been done.
commandosqueak
PostPosted: Sun Feb 28, 2016 2:14 pm Up
agreed! I am on my third axle. As it has a warranty every time it goes I have it replaced. I got mine from axle direct for £275 ish on an exchange bases. easy enough to do!
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
