Latest: Puggingalong
Overall: 17129
Online Now [325]:
Visitors: 324
Today: 49819
Total: 101744747
Forums › The Car › 206 Problems › 2006 Peugeot 206cc 2.0 petrol EGR problem??
Kevwilson1982
PostPosted: Wed Mar 09, 2016 7:29 am Up
Hi folks,
Ive recently bought a 206cc with a EGR problem. Ive had a quick look under the bonnet and noticed that there is no wiring harness connected to the EGR valve and i cant seem to find the connector anywhere. Does anyone know where the harness goes? surely it hasnt fell off lol
PostPosted: Wed Mar 09, 2016 12:35 pm Up
Are you looking in the correct place?
Kevwilson1982
PostPosted: Wed Mar 09, 2016 3:58 pm Up
Lol yes I'm looking in the right place. Top right corner of the engine beside the coil pack. The car is a repairable write off so trying to get it back on the road. It also has the anti pollution fault (obviously due to the fact the EGR is not connected.
