Latest: cogeim7
Overall: 17185
Online Now [626]:
Visitors: 626
Today: 17585
Total: 147541891
Forums › The Car › 206 Problems › GTI180 won't start
GTI180 won't start
Scottparkes81
PostPosted: Sat Mar 12, 2016 4:05 pm Up
Right....
Been and had my car mapped today on rolling road and its developed an issue I believe not related to the map.
It has occasionally ran lumpy but clears itself. Today on the rollers it ran fine then just went lumpy and wouldn't Rev very well, we turned off and it won't start again. It comes up on the fault reader with the p0342 camshaft sensor fault. We have tried a new cam and crank sensor in off our other 180 but still won't go, symptoms are comes up as Eco mode active on display. Turns over and occasionally pops and spits flames out but will not fire. No rattles, clunks are metallic sounds. Any one got any ideas??
Scott
PostPosted: Sun Mar 13, 2016 3:59 am Up
Forget ECO MODE, that's not a problem.
Put the original factory ecu map back in to the ecu & start afresh.
jay_gti180
PostPosted: Sun Mar 13, 2016 8:45 am Up
I had this issue mate, was told could be multiple things so not exactly a great help.... Here are the things i changed and eventually resolved the issue:
Plugs
Coilpack
Cam and crank sensor
Map sensor
Earth cables
For me was the cam sensor though
PostPosted: Wed Mar 16, 2016 7:07 am Up
if it gives you that camshaft sensor fault,it will never start as there will be no line up with crankshaft to have the DTC point,anyway,check the harness if it's line is working well,if all is well,then you have a fault with the ECU itself because of remapping.
