![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Problems › Fuses and what effect they have on non-starting |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Thu Mar 24, 2016 10:35 am |
Hello all,
Was wiring up a rear camera from the reversing lights when I accidentally shorted out a wire to the car body. The effect was that the car would not start, plip key would not lock/unlock doors, no headlights, no radio, no wipers, no heater, no safety warning lights. The only thing which worked was side lights, instrument lights & interior light. The fault was found to be a blown fuse.
How the hell did all this lot go down when the culprit fuse was for the
Multifunction display, navigation control unit, boot lighting, audio equipment - 20A fuse number 4.
How can this fuse control all that lot - I'm baffled.
Anyone got any ideas ?
Regards
Jim
| | ![](images/spacer.gif) |
Posted: Thu Mar 24, 2016 2:43 pm |
Have you checked the main fuses.
4, BSI 70Amp
5, BSI 70Amp
7, Ignition Switch Supply 30Amp
| 206 2ltr Hdi glx 53 plate | |
Posted: Fri Mar 25, 2016 1:49 pm |
And the lesson learned? Disconnect the battery before fiddling with the electrics ... ![Smile Smile](images/smiles/icon_smile.gif)
| ![](themes/base/images/forums/otr.gif) |
