Latest: S2cgm
Overall: 17178
Online Now [90]:
Visitors: 89
Today: 18449
Total: 137288097
Forums › The Car › 206 Problems › 04 206 1124cc
04 206 1124cc
adran
PostPosted: Fri Apr 08, 2016 3:08 pm Up
my 206 is only running on no 2 and 3 cylinders, i have replaced coil pack, injectors and spark plugs, valve timing and compressions spot on, not firing on no 1 and no 4, can anyone help me sort it out, thanks, adran
PostPosted: Fri Apr 08, 2016 5:57 pm Up
How have you worked out that it's only firing on 2 and 3?
Any fault codes showing up?
Has it just started misfiring or was any work done just before it started?
adran
PostPosted: Sat Apr 09, 2016 8:20 am Up
NO FAULT CODES,STARTS FINE BUT RUNS ON 2 AND 3, I CHECKED EACH INJECTOR FOR TICKING 2 AND 3 TICK OK BUT 1 AND 4 NOTHING, FITTED SECOND HAND INJECTORS AND COIL PACK BUT NO DIFFERENCE,I HAVE CLEANED STEPPER SWITCH AND OTHER SENSORS,COMPRESSIONS 150, VALVE TIMING OK. !
PostPosted: Mon Apr 11, 2016 3:57 am Up
you need to check the wiring loom,if there is any damage,if all is good,then i think you have a problem with the ECU
adran
PostPosted: Mon Apr 11, 2016 3:21 pm Up
I will get it checked out tomorrow thanks.
adran
PostPosted: Tue Apr 12, 2016 2:13 pm Up
checking the wiring and tested the coil pack connector, the 4 leads that go in clockwise from top left yellow/grey, grey/brown, red/white red/blue, on engine tick over i light tested them 3 leads light up ok the grey/brown is dead, should they all light up ? the engine ticks over fine at a steady 900 revs but will not road drive no power, any advice thanks.
adran
PostPosted: Mon May 23, 2016 3:30 pm Up
HI, Thanks Timon2210 it was the ECU,
car now goes well, Thanks to all for their advice,
adran.
PostPosted: Wed Jun 01, 2016 1:29 pm Up
adran.
You are Welcome,glad that you got it fixed Smile
