Latest: Beduff1977
Overall: 17134
Online Now [626]:
Visitors: 625
Today: 129697
Total: 108945493
Forums › The Car › 206 Problems › ABS modulator help
ABS modulator help
Pugpug77
PostPosted: Wed Apr 20, 2016 10:27 am Up
Hi I've had an ABS light on the dash of our 206 1.4 manual petrol car I've had the code read today and it indicates the modulator as the problem now from reading online I'am guessing I need to replace the pump and ABS ECU? so I'am also assuming that it will need to be identical in part numbers too?
This is turning into a costly little car Sad
Pugpug77
PostPosted: Wed Apr 20, 2016 10:55 am Up
Also if anyone can help me identify which number on my unit am I trying to match with a donor unit please thanks
Pugpug77
PostPosted: Sat Apr 23, 2016 12:03 pm Up
Can anyone help with this?
The ecu part of the module has a part number that is really difficult to match with a second hand part and the ones I do find are crazy money!
PostPosted: Sat Apr 23, 2016 1:46 pm Up
These people will be able to help you with a repair or replacement.
www.actronics.eu/en/sh...abs-ecu-en
Does this 206 have ESP fitted?
Pugpug77
PostPosted: Sat Apr 23, 2016 1:58 pm Up
I have no idea what ESP is?
PostPosted: Sat Apr 23, 2016 2:11 pm Up
Electronic Stability Program.
There will be a switch yo the left of the passenger airbag disarm keyswitch marked ESP if you have it fitted.
It would have been an optional extra when your car was built.
OR send me the VIN via PM & ill have a look on Peugeot Service box to see which ABS system is fitted.
Pugpug77
PostPosted: Sat Apr 23, 2016 2:27 pm Up
Pm sent
PostPosted: Sat Apr 23, 2016 2:45 pm Up
Your 206 has ABS TEVES MK70 fitted.
Pugpug77
PostPosted: Sat Apr 23, 2016 2:53 pm Up
Am gonna take it out tomorrow and open it at this point I have nothing to loose lol
