Latest: lio94
Overall: 17181
Online Now [415]:
Visitors: 414
Today: 101966
Total: 141741583
Forums › The Car › 206 Problems › 2006 206 front subframe securing bolts
gabby01
PostPosted: Sat May 07, 2016 1:41 pm Up
hi, i am new to this forum and i am needing some help, my sons 206 requires a new steering rack which i have, problem is when i loosened the front subframe bolts the caption nut is also turning which means i cant lower the frame to allow the old rack to come out. does anyone know what size the nut is that is inside part of the chasis, if i can get a spanner on it i may be able to remove them. the rear two bolts are ok. has anyone any ideas? thanks in advance. needs the rack changed for MOT.
