Posted: Sat Aug 01, 2015 11:10 am |
Hi all, small problem and hopefully someone can shed light on it. 52 plate 2.0HDi. Had new brakes, pads, discs recently fitted. When I pull off no issue, when I drive no issues, when I brake at speed no issues. When I brake at low speeds and come to a full stop I get a creaking noise from the front and a knocking sound. Brakes recently checked and no issues. Any ideas? I am thinking suspension but which part? Cheers
Posted: Mon Aug 03, 2015 6:15 am |
Check the lower engine mount,that holds the engine close to the axle.
Posted: Tue Aug 04, 2015 3:33 pm |
Cheers I will take a look at that, a few other posts on different forums have suggested that
Posted: Sat Aug 22, 2015 5:12 am |
Any update about the knock sound?did you got it sorted?
Posted: Thu May 12, 2016 1:31 pm |
Hi PhilC1974 (or anyone else who can help). Did you get the creaking and knocking noise sorted. If so, was it the lower engine mount which Timon2210 suggested, or was it something else? I have exactly the same problem and have been trying for ages to find the cause. I really would appreciate it if you would take the time to answer.
