Posted: Thu May 12, 2016 12:02 pm |
Hi
I have a 2006 206 1.4 8v kfw engine. Just had new timing belt kit fitted by local garage and new throttle body, peddling, lambda sensor and water pump changed still when I put my foot down the car only revs to 4500 rpm and fluctuates. If I increase my rpm gently the car reaches 6000 rpm, can't find why this is any ideas please?
Posted: Thu May 12, 2016 12:38 pm |
Should be electric fly by wire throttle set up.
You cant just fit a new one & expect it to work, needs setting up.
Peugeot Planet time.
Posted: Thu May 12, 2016 1:09 pm |
It is not fly by wire it is a electric throttle body
Posted: Fri May 13, 2016 3:16 am |
Mikewhh wrote: |
It is not fly by wire it is a electric throttle body |
Fly by wire (electric throttle body) where a sensor on the pedal sends the signal on the position of the pedal to the ECU which then in turn sends the signal to the throttle body to tell it how far to open the butterfly, as well as how much fuel to deliver via the injectors as opposed to a physical cable running between the pedal and throttle body which opens the butterfly in direct relation to how much the pedal is pressed.
Posted: Fri May 13, 2016 12:18 pm |
how do you set them up?
Posted: Mon May 16, 2016 2:21 pm |
Following this with interest, as I was at one time contemplating fitting a larger FBW throttle body from the EW10a to my own car.
Why is the the case?
Posted: Tue May 17, 2016 4:36 pm |
This is really frustrating because i can't think of anything else I can do it almost like when I put the throttle pedal down fully it hits 4500 rpm and the struggles
Posted: Wed May 18, 2016 5:07 am |
MrBSI wrote: |
Peugeot Planet time. |
Posted: Wed May 18, 2016 6:23 am |
Cooling fan needs to be in working order to.
Follow the on screen instructions & I would recommend a fully charged laptop battery & / or a car charger.
Posted: Wed May 18, 2016 7:25 am |
Where do I get Peugeot planet ?
Posted: Wed May 18, 2016 11:38 am |
You can have a look at the forum Planet map for members who have it:
www.206info.co.uk/Foru...55053.html
Or if you want to invest for yourself, Peugeot Planet / Diagbox software is easily / freely available all over the internet
You then need the Lexia interface & leads - this is where the cost comes in, everyones favorite online auction site.
You also need a laptop running a 32 bit version of Windows.
If your laptop runs 64 bit Windows you will need to run a virtual machine 32 bit version of Windows & install Planet or Diagbox in to that.
Planet / Diagbox wont run on 64 bit versions of Windows.
Posted: Mon May 23, 2016 2:52 pm |
does anyone near kings lynn have peugeot planet? i need of help
Posted: Thu Jul 07, 2016 4:23 pm |
Hi I have changed every sensor on this bloody car still not getting full power. I was told that it could be head gasket letting air in and that why, could this be true and how much does it cost to have a head gasket done
Posted: Thu Jul 07, 2016 4:32 pm |
[video width=250 height=200]https://youtu.be/4Wr1Yof4zAI[/video]
