Latest: tbafonso
Overall: 17130
Online Now [49]:
Visitors: 48
Today: 5750
Total: 104155784
Forums › The Car › 206 Problems › Clutch pedal problems
Pugpug77
PostPosted: Wed Jun 08, 2016 1:42 pm Up
Took the car out a few days ago and managed to stall it twice as the clutch pedal felt strange not all the time I might add and I find it hard to describe but it felt like it didn't glide properly a bit sticky maybe?
Today on the way home the clutch made a clicking noise when I pressed it then I couldn't get it out of gear I did after a few moments and then was on my way but it defo doesn't feel right and it's making clicking noises often
I do t think it's the clutch itself or the slave cylinder as I've had these go on previous cars this feel like it's the pedal ??
PostPosted: Wed Jun 08, 2016 3:25 pm Up
What 206 is it?
Depending on what side the steering wheel is on & which engine you have, it could be either a cable operated clutch OR a hydraulic clutch as the 206 uses both types.
Pugpug77
PostPosted: Wed Jun 08, 2016 5:07 pm Up
It's a 2008 look 1.4 right hand drive
PostPosted: Wed Jun 08, 2016 5:08 pm Up
Should be a self adjusting cable operated clutch then.
Pugpug77
PostPosted: Thu Jun 09, 2016 2:31 am Up
The car won't go into gear at all now I'll try getting the cable changed first and see how things are
