Posted: Sat Jun 04, 2016 7:05 pm |
Hi looking to get new brake pads for my car and confused eurocarparts have two dif sizes and not sure which one it is any ideas
I have a 2006 1.4 8v
Posted: Sat Jun 04, 2016 7:49 pm |
Check these folks out brakeparts.co.uk
They've got diagrams of pads and fittings, so you can compare to what's on your car before buying.
You might have either Bosch or TRW front brakes system and that lottery can be across any model of any year.
Last resort would be to PM your VIN to anyone on here who has access to pug's servicebox, they can check your car's exact makeup (I can do that, but starting me holidays tomorrow, be quick )
Posted: Sat Jun 04, 2016 9:04 pm |
Ok, according to your VIN pug says this:
Brakesint says there are 4 choices
Given the two sources and googling part numbers, I'd go with this one.
But like they say, do remove the wheel and ensure it's a visual match first. Good luck!
Posted: Sun Jun 05, 2016 3:41 pm |
If you check the characteristics on service box after you enter the VIN, it should tell you which ones are fitted
Posted: Sun Jun 05, 2016 3:50 pm |
We can see from Service Box it had the 247mm x 20.4mm vented front brake set up when it left the factory.
Posted: Tue Jun 07, 2016 7:14 pm |
Thankyou fitted new pads and done easily thanks again
