Latest: Stu-mill
Overall: 17131
Online Now [53]:
Visitors: 52
Today: 77882
Total: 104886693
Forums › The Car › 206 Problems › Airbag Warning light (P0802) Open circuit, horn not working
mvale291
PostPosted: Sat Jun 18, 2016 12:27 pm Up
I've recently bought a Peugeot 206 (2004), since buying the car the airbag warning light is constantly on and I can't find a way to remove it. Checked fuses and they all seem fine. Diagnostics says P0802 open circuit - can't remember exactly what it said.
Since then the horn has decided that it doesn't want to work either and It needs an MOT asap.
Any one that can help???
PostPosted: Sat Jun 18, 2016 3:04 pm Up
Sounds like it needs a new Comm2000 unit.
mvale291
PostPosted: Sat Jun 18, 2016 3:12 pm Up
Is that something that can be easily installed, or is it likely that I will need to take it to a garage to be fitted?
PostPosted: Sat Jun 18, 2016 4:25 pm Up
Steering wheel needs to be removed which means removing the drivers airbag.
mvale291
PostPosted: Sat Jun 18, 2016 9:13 pm Up
Ok
I'll see what I can do.
Thanks for the help Smile
gazza82
PostPosted: Wed Jun 22, 2016 2:12 pm Up
Multiplex version (2001 on) has a clip on airbag ... there are two slots in back of steering wheel to release it.
Wheel is held on with a TORX screw (can't remember the size) ... and pull off.
Com2000 units are varied .. make sure you get the same type!
I did a write-up for this forum .. but I think it was lost when the forum had to be rebuilt .. Knew I should have done it as a PDF!
mvale291
PostPosted: Wed Jun 22, 2016 2:15 pm Up
Thanks, there's a few different numbers and stuff on the unit, which one do I need to use to find a replacement?
1. 345 724 28
2. 96530924XT
3. 4471 - RL
