Online Now [538]:
Visitors: 537
Today: 10724
Total: 105904765
Forums › The Car › Solved 206 Problems › 1.4 hdi overheating, is it head gasket?
thng33
PostPosted: Wed Jun 22, 2016 11:40 pm Up
bought a 04 plate 1.4 hdi a month ago, 80k miles on it. had it serviced seemed everything was fine. car has always run a little hot, i thought, since it ran at 90-100 or 80-85 when driving a bit slower.yesterday night on the highway i was pretty much topping it out when i noticed the temperature was red and stop sign flashing at me. i pulled over right away, engine stayed in hot for maybe 1 to 2 minutes. after 10 minutes the temperature was back to 90 but since that incident the engine has been running quite hot. its now regularly running at ~ 120 and if pushed it will get into red again. is this the head gasket?
southwestchap
PostPosted: Thu Jun 23, 2016 8:44 am Up
Is there bubbles or Oil appearing in the header tank?
Is both rubber radiator pipes getting hot after running?
thng33
PostPosted: Thu Jun 23, 2016 11:10 am Up
dont see oil in the header tank, havent checked about the pipes, how would i check these, just with my fingertips?
southwestchap
PostPosted: Thu Jun 23, 2016 11:16 am Up
yeah just by touch,
give it a rev and see if any bubbles appear in the tank.
PostPosted: Thu Jun 23, 2016 12:17 pm Up
Is the cooling fan working?
Diesel run cooling then petrol & its rare for the cooling fan to cut in during normal driving.
Cooling fan wiring rotting out is a known weak point on the 206.
southwestchap
PostPosted: Thu Jun 23, 2016 12:26 pm Up
thng33 wrote:
at what temperature do i check for bubbles? any temperature? do i literally open the cap to look or do i keep it closed? sorry for dumb questions
Take cap off, start and leave car running for 10 minutes or so. Generally once the engine is climbing up through the temperature.
thng33
PostPosted: Thu Jun 23, 2016 4:14 pm Up
i can see the water moving when its revving, not sure if its bubbles. both pipes coming off the radiator are hot indeed, fan is working
southwestchap
PostPosted: Fri Jun 24, 2016 9:28 am Up
Coolant is circulating, Do the heaters get hot? Temp sensor could be lying...had that before on a 2.0hdi. Would need to put on diagnostics to check though
gazza82
PostPosted: Fri Jun 24, 2016 9:44 am Up
Try the sensor first ... my 1.4hdi did that .. scared the sh*t out of me until I realised that the engine wasn't that hot ..
Realised it was the sensor when it started doing it before I'd even got out of the driveway!!!
Disconnect sensor, pull circlip out holding it in to housing, pull sensor and stick thumb over hole to minimise coolant loss, stuff new sensor back quickly, place clip, replace connector.
thng33
PostPosted: Fri Jun 24, 2016 12:22 pm Up
the heaters do blow hot air at me when i turn everything off. not sure its the sensor because it stays around 100-110 when driving normally and only starts overheating after 10 minutes of spirited driving
southwestchap
PostPosted: Fri Jun 24, 2016 12:32 pm Up
flush the coolant and make sure nothing is jammed in front the radiator.
thng33
PostPosted: Fri Jun 24, 2016 1:46 pm Up
left pipe coming from the radiator is slightly cooler if that matters. water level doesnt look like has gone down even though the needle has hit red 3 times now. i immediately turn it off every time, once the engine has been off for 10 minutes its back to ~110
thng33
PostPosted: Fri Jun 24, 2016 1:47 pm Up
could be the sensor, there are laser that measure temperature right? if i point that at the radiator pipe how accurate would the reading be?
gazza82
PostPosted: Fri Jun 24, 2016 1:56 pm Up
Close enough .. or cheaper option is a thermometer in the header tank?
thng33
PostPosted: Fri Jun 24, 2016 3:59 pm Up
nope sensor doesnt lie, its overheating like s**t. ill flush the water but i dont think the problem lies there
