Online Now [572]:
Visitors: 571
Today: 37117
Total: 146935667
Forums › The Car › 206 Problems › Bleeding 1.1
Bleeding 1.1
banksy66
PostPosted: Sun Jul 24, 2016 5:55 pm Up
Hi
No I wasn't swearing with the title, I'm having trouble with the cooling system on our 1.1, 2002 reg
I have drained and flushed the cooling system today and replaced the thermostat. I have found 2 bleed screws, one is on the bulkhead for the heater, and one is a large nut on the thermostat housing. Top and bottom hoses and radiator are getting hot and the cooling fan cuts in and out as required. Unfortunately I have no heater function, I'm just getting cold air out. The temp gauge is working normally and no more air is coming from either bleed screw. Is there a bleed screw I have missed or is there something else I have missed?
Many thanks in advance for any help/advise
