Online Now [481]:
Visitors: 480
Today: 137315
Total: 105714196
Forums › The Car › 206 Problems › 206 wont start..empty on dash, on first turn of the key
penang206sr
PostPosted: Thu Jul 21, 2016 8:34 pm Up
Hi mate... Hope all of us are in god bless
Im using 206, 1.4L Auto... Big headache on the probably
After my top overhaull.. Its start ok..,
Then i off the car to change coolant.. Yes my mistake im careless on batttery changing.. Then i try to start again..
On first turn of the key....nothing appear on dash.. Totally blank
On second turn of the key...all light on dash appear.. Wiper moves.. Headlight, STOP, fuel sign, and someother appear on dash
Then i start the car...it crank but csnnot start the engine..
Ok...i check everything..the both earth cable(gearbox & body)...clean & stuff
Battery ok..fill up oil..topup coolant..check and change all fuse(compartment & engine)..
I do the reboot of bsi...alot of time..failed..still same probably
For your info... My mfd and remote car is broken(didnt use them for along time)
I skip the procedur on press alarm fo 10sec... But using the original key with transponder..
Somebodyyyy help...all sifu...
Thank you very much
PostPosted: Sun Jul 24, 2016 1:18 pm Up
Did you make sure that the gearbox stick is on the N or P position,as if it's on the R or D,car will never start even if everything is spot on as you said.
penang206sr
PostPosted: Mon Jul 25, 2016 12:05 pm Up
Yes bro... So sure it on P...
penang206sr
PostPosted: Mon Jul 25, 2016 2:08 pm Up
