Latest: lio94
Overall: 17181
Online Now [110]:
Visitors: 109
Today: 4196
Total: 141314989
Forums › The Car › 206 Problems › Temperature, control arm bushing, radio code
Sofa.King.Happy
PostPosted: Tue Jul 26, 2016 3:01 pm Up
Hello again. I'm having small problems with my 206 Gti and I hope you guys help me.
First of all, is it alright that engine temp ranges to 80-90? When I'm driving (especially highway, but sometimes in the city) it drops to ~80-85 degrees, when I'm stationary it goes up to 90 or even more (then the fan does his job).
Can cold air flow cool my engine that fast? I'm used that engine temp stays at 90 degrees all the darn time!
I've changed thermostat (Vernet) and coolant a week ago, it didnt changed.
Secondly, I'm planing to put polyurethane into control arms to stiff my suspension a bit. The problem is its going to be a bit expensive to change all four bushings at once. I'm thinking of changing two now.
Does anybody know which bushings are best to change (front or rear)?
Or should I save and change all of them at once?
Whats more, my original Peugeot's blaupunkt radio asks for code everytime I turn the ignition or start the engine.
As far as I remember, it didnt ask for it untill I took it out for the first time. Or the time I took the battery off. Or it did ask for it, I dont really remember!
Is it normal to enter code everytime?
PostPosted: Tue Jul 26, 2016 9:15 pm Up
1. Thats normal for the engine to sit around that temperature, if you really unsure, bleed the cooling system again after replacing the temperature sensor
2. The main ones i would do are the front ARB and rear axle bushes (dont bother with the inserts, only fit the full bush), the others arent worth it in my eyes
3. Does it forget the code? As once its be input after forgetting the code, it should never ask again
PostPosted: Wed Jul 27, 2016 7:31 am Up
Has the car previously had an aftermarket head unit fitted?
PostPosted: Wed Jul 27, 2016 8:12 am Up
Does the radio remember radio stations?
Sofa.King.Happy
PostPosted: Wed Jul 27, 2016 1:23 pm Up
Front ARB and rear axle. Thanks!
I'm not sure if it had an aftermarket head unit in, but I think no. (but what if it did?)
The radio does remember radio stations. Any thoughts guys?
Something more:
Is it worth installing front strut bar? I've read something that it doesn't make a difference here. If it's true, why?
gazza82
PostPosted: Thu Jul 28, 2016 8:31 am Up
I thought most 206's had Clarion radios?
early models (non-plex) has a strange shaped radio with it's own small screen. Remote stalk is long and thin. That has a code.
later mux models had a rectangular radio without a screen so it uses the MFD on top of dash and remote is shorter and flatter. That is programmed into BSI.
PostPosted: Thu Jul 28, 2016 9:31 am Up
I was thinking that if at some point an aftermarket unit had been fitted then the wires hadn't been swapped back and the unit was receiving a switched feed instead of a constant live which was causing it to reset.
gazza82
PostPosted: Thu Jul 28, 2016 9:37 am Up
Or it was swapped out for a reason .. the Blaupunkt is bust! Smile
Sim
Then it makes me wonder of how many of Blaupunkts are actually out in the wild Smile www.206info.co.uk/Foru...63493.html
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
Sofa.King.Happy
PostPosted: Fri Jul 29, 2016 11:38 am Up
This is the head unit I have, guys.
Mine's non-plexed and there's that little screen on the top in the middle of the dash.
Well I'm a huge noob when we talk about electrics. What wire would be where, maybe you know?
What is more guys, I reallly think it started to ask for code after I took the head unit out for the first time or when I unplugged battery. What could I've done? I think I plugged all the wiring.
And hey, is it cool that everytime I start a car climate control goes to auto and AC on? And it doesnt work (even the screen keeps black) with ignition on, is that alright too?
